DiskDoctr
Jan 06, 2014Explorer
wa8yxm wrote:
There we go again with AIR OUT OF THE LINES.. When are you folks going to learn that any air that might have been in the lines vainished when the salesman lit the stove during the PDI, there is no air in the lines has not been since the first owner took posession.
Where did you get your information? Bleeding the air out of the lines in this method is fairly common knowledge...furthermore, it is good practice to turn off your propane tank while running a lit burner and letting the gas burn off before disconnecting your tank fitting, eliminating the pressure in the line.
It is also wise to store one's rv without pressure in the lines.
The advice given is sound and will serve the OP well. But you won't be fined if you choose not to follow it...feel free to choose your own road if you like ;)
