cannesdo
Dec 18, 2016Explorer
Lighting pilot in a Suburban H20 Heater (older)
My rig is a 2001. I have the water heater that doesn't have the black knob that says "Pilot" and "On". I just have an on-off switch and inside a water heater gas button that says on and off with a light next to it that says "reset" that isn't on. When I turn the gas button inside to "on" then go outside I hear it going "t-t-t-t-t", trying about 3 times. I've tried lighting it where it shows in the manual to light it and nothing happens. I don't smell any gas at any time. Should I smell some when it's going "t-t-t-t-"? There is no knob that says "pilot" or anything, just that electrical on/off switch which should be left off, yes?
Any tips would be appreciated. I think I had it running on gas years ago but haven't run it on gas since.
Will it only light during the "t-t-t-t-" moments? I've turned it off and on 3 times now and still no reaction.
If I remember right...you can change the heater setting from on and heating the water to just the pilot light with the on/off gas button in side, yes?
