- wopachopExplorerOh cool isn't the HD Carlisle the one to get these days?
- dkreuzenExplorerI ran Greenball Tow-master 15" tires for about 5 years (the only ones I could get locally at the time). I averaged about 18 months before one of the set would start separating. Since I bough the "certificates" I got them all replaced each time for almost free but I got tired the continuous fear of a blowout. When the new Carlisle Radial Trail RH tires came out in 2009 I gave them a try. Never had one issue since. Replace them after 7 years and got another set which I haven't had any issues with either.
- wopachopExplorerBlow master comes in many models. Their premium tire is called the ASC.
I'm leaning towards the goodyear's now. Price is so similar I just want the best 15" tire I can get. - EsacnjExplorerTerrible tires. I had a blowout start of 3rd season do to belt shift. Often referred to as Blowmaster on the forums.
- wopachopExplorerHey thanks will check those out!!!
- Cummins12V98Explorer IIIChinese Made ****, spend your money wisely with the GY ENDURANCE.
- TOW-MASTER ASC goes to LRF and 95 psi if the wheels are rated for it.
https://www.greenball.com/brands/greenball/tow-master-asc
Also carry aluminum or steel wheels for the full rating. - LwiddisNomad III“Hoping the come back saying its something i can try at my own risk.“
Why would any careful business person advise you to try exceeding max rim air pressure...your risk or not? - 2oldmanExplorer III see some posts on these in 5ers, TTs.. etc. Not here.
- wopachopExplorerThe website says 15' wheels need a spec of 3100lbs or higher. Darn i checked and mine are rated at 2800lbs.
I just wrote the company with that info. Hoping the come back saying its something i can try at my own risk.
Does it have to do with holding the higher PSI?
Want to switch to metal valve stems regardless. If anyone has advice on picking out good valve stems im all ears.
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 08, 2026
