hershey's avatar
hershey
Looking for a LED conversion for 12 V florescent fixture
My Thin-Lite 30W mdl 746 12V two tube florescent ballast has burned up. Its about $40 to change it out so I thought it might be a good time to replace it with a LED conversion. I saw the led replacements at the Big Tent in Quartzsite and just poo poo'ed the idea because of the cost. Now its more of a do-able task.
I Googled the replacement but came up empty handed. Hoping that someone can give me a vendors address and share their experience with the changeout. Is it as bright as florescent??? Don't bother??? Great idea????
  • 1775 wrote:
    I have seen two different approaches to LED replacement of RV fluorescent tubes. One is a strip of LEDs that attach to the top of the fixture where the tube had been and then plugs go into the receptacles that ends of the tube attached to. The other type is a tube the same as the fluorescent full of LEDs and this is just a direct replacement of the original tube.
    http://www.rvledbulbs.com/product-p/18-0117.htm
    Thanks to all for the replies. This is what I've been looking for. Question? Is one LED tube enough to duplicate the available light from two florescent bulbs????
  • I have seen two different approaches to LED replacement of RV fluorescent tubes. One is a strip of LEDs that attach to the top of the fixture where the tube had been and then plugs go into the receptacles that ends of the tube attached to. The other type is a tube the same as the fluorescent full of LEDs and this is just a direct replacement of the original tube.
