carjockie's avatar
carjockie
Lost power to 3 outlets
i lost power to 3 electrical outlet, check the ground fault but that didn't power the outlets. Check the circuit breakers and they are on on, any other suggestion would be appreciated. Right now I have a double male supplying power to the three outlets. Is it possible I've have a broken wire?
❚ Did you miss the FTS "Announcement : READ BEFORE POSTING HERE"?
    Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum sites,
    member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related
    questions. Instead, select the Sub-Forum which corresponds to the subject of your topic.
    Thank-you!
    Moved from FORUM TECHNICAL SUPPORT
  • It could be the outlets on inverred power, so isolation switch or battery
  • bad plug or a bad wire connection under or in the slide depends on how they connected the wires
  • RV manufacturers use the absolute cheapest push on wire outlets. They also daisy chain the wiring. So to fix you need to go to each outlet, remove it from the wall and look. My guess you will find a wire off.
Having RV issues? Connect with others who have been in your shoes.24,288 PostsLatest Activity: Jan 09, 2022
