BobsYourUncle
Feb 17, 2017Nomad
*Update on problem:
It was so blinkin cold here that I really didn't feel like diving into it and freezing my a...a.. Adam's apple off.:B
But with a recent chinook most of our snow is gone and it's nearly T shirt weather.
I tried the battery disconnect thing. Didn't do anything. Was going to try the extra ground but didn't do it.
Had some time today and I pulled apart the boot that goes from the door to the body.
Not a lot of room in there but I managed to tear away the black tape wrapping and expose the wires. I found one brown wire completely severed from flexing wear. 3 other wires are partially broken, the insulation is cracked and bare wire exposed.
I got about a 2 inch piece of 18 ga wire and made a bandaid splice to the broken wire. Twisted it together and taped everything up.
Tried it out and I have all my electrical back again. :) Yahoo!
Went to the dealer today for an oil change and fuel filter and while I was waiting I asked at the parts dept how much for the door harness. $466. And it has to be ordered in from Pluto or some place. I thanked the helpful parts guy and declined.
So I have the problem nailed down. It will work with the bandaid fix for a short while but I must pull the harness out and properly solder and shrink tube in several splices.
Going to do the splices in the door with about a ten inch piece going into the body. That way the joints will not be inside the flex boot.
Cheap fix, it'll just take a few hours of my time to do it.
Sure glad I have spent my adult life fixing stuff and know how to do this.
Thanks to everyone for your input and wonderful suggestions!
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
