- 30 pounds is 7 gallons, so looks like 90 pounds +-
- Horizon170ExplorerAfter looking at my system I think the best way is to add a "T" after the regulator, as cmeade suggested, and put a separate regulator and a valve in the line on the 30# tank.
That way I can remove the 30# and refill and still have the frame tank available.
I have a 22 gallon frame tank----how does that relate to pounds?
Marvin
PS, I found my answer.
http://www.missiongas.com/lpgbottledimensions.htm - Horizon170ExplorerThanks everyone.
cmeade, your idea will work but I must have a closer look at my system. I just want one regulator and be able to switch back and forth. I know I would need a high pressure line to go from 30# tank to regulator and I would have to have two shut off valves installed.
Thanks, Marvin - cmeadeExplorerIf you are determined to have it your way then install a T fitting with cap and shutoff valve at genny to supply line. Regulator would be attached at portable tank because your 30# tank is unregulated. You would then have a propane hose from 30# tank and regulator to T fitting to genny with shutoff switch "off". Cap the T fitting and turn shutoff valve "on" and frame tank now supplying.
- lc0338ExplorerIf your generator is already plumbed into the frame tank I don't believe I would monkey with it. I would just get an extend a stay and hook it to your frame tank. It would probably be less work.
https://www.youtube.com/watch?v=dEzwrjCvCOA - mcheroExplorerExtend-a-stay comes to mind.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
