Sox_Fan's avatar
Sox_Fan
LP Grill Connection
I have reviewed a number of threads but don't seem to find what I am looking for, though I didn't go back years and years.
I have a Class C with a 60 lb propane tank permanently mounted. It is regulated for use with the appliances (fridge, water heater and stove) as well as the generator (Onan 3.6kW MicroLite). It actually appears to have 2 regulators (I haven't removed the protective covers to verify) but I suspect one is for the appliances and the other is for the generator, both are mounted near the tank.
I would like to run a connection for my grill that currently uses the 1 lb cylinders. I understand that the regulated pressure to the grill (after the regulator using the regulator it came with) is slightly higher than the appliance regulator so a simple connection to the regulated side of the internal low pressure line won't work well (understanding that removal of the grill regulator is required). Is there a quick disconnect connector/hose that would connect to the grill fitting if an additional regulator was installed near the tank for this specific purpose?
Bottom line is I want to connect my existing grill to my RV's propane tank to avoid carrying the 1 lb cylinders and I want to do it right so it is safe and doesn't sacrifice the grill performance.
Thanks in advance...
Bob
  • GASMAN6674 wrote:
    ChooChoo man is correct unless the manufacturer of you grill offers a low press conversion kit it will not work. Some have removed the disposable bottle regulator/hook up an ran low pressure into there grills and it works for them. But most of the time if you remove the regulator/hook up you lose your control valve. Your grill needs to be similar to a full size one but smaller of course.
    I have my eye on a stainless steel master forge at Lowes just waiting on clearance.
    The hose above connects to where a 1lb bottle will connect to, and the other end will connect to the TEE.
  • ChooChoo man is correct unless the manufacturer of you grill offers a low press conversion kit it will not work. Some have removed the disposable bottle regulator/hook up an ran low pressure into there grills and it works for them. But most of the time if you remove the regulator/hook up you lose your control valve. Your grill needs to be similar to a full size one but smaller of course.
  • I may be wrong, but you need to try and install one of these between the tank and the regulator.
    extend a tee
    Then get the appropriate sized hose to your grill.
    And it should look something like this.
Having RV issues? Connect with others who have been in your shoes.24,318 PostsLatest Activity: Sep 14, 2025
