full_mosey
Jun 13, 2020Explorer
pianotuna wrote:
Hi John,
It is good to know there is an inverter microwave. Is the temperature continuously variable? i.e. can you "dial in" the watts?
I believe you meant induction stovetop not microwave.
There are 15 settings for heat. You can set the heat by Watts or Temperature. The Watts range from 100-1500; temperature ranges from 140-400F.
My favorite feature. Sometimes you need to lift the pan to shake or flip the food. If you lift the pan off of this stovetop, it pauses and does NOT SHUT OFF right away! It will beep for about a minute. You may resume cooking instead of having to repeatedly redo your temp settings. Did I say I like this feature?
HTH;
John
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
