bennefim's avatar
bennefim
Manual fan setting for gas furnace in rv
Our coach Is set up to heat the basement via duct work when gas furnace is running. We use small electric heaters rather than burn propane, which works well but doesn’t help the basement without air circulation. If we could turn just the fan on the gas furnace on, it would send heat to the basement.
Anyone done this or had the control modified for manual fan use?
Doug
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
