MEXICOWANDERER
Sep 27, 2017Explorer
Don, I sure recommend you get your mitts on a ...
Which will insure you are not over amping the battery. I shoot sides of cells then both pos and neg posts.
Play around with normal charging temps. Use Delta T calculation for absolutes.
Immersed in a liquid the only way to do a plate burn through would be an absurdly high shock of excess wattage.
With the BORG charger I worry not. Close to 100 amps because the entire country is fixated with 30 amp breakers or fuses. Too much voltage drop at the receptacle? A twist of the wrist dials the Borg back, enough that an ancient Honda 600 or Harbor Fright 800 loads right to the last noodge of wattage. But the BORG is not PFC. I am getting ready to design a twin Meanwell RSP 1500-15 charger. This will be a 140 amp monster and it will have PFC and remote thermistor sensing for the float unit.
If ANYONE out there has broken, old, ugly unused 15 amp chargers out there I will buy them. For the Hyperwatt and 3KW Borg projects. PM me. Old fashioned 15 amp chargers were about the size of a 12-inch cube
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
