Crumm
Apr 19, 2015Explorer
ralphnjoann wrote:bgum wrote:Actually this probably won't work. Most, but not all, microwaves reduce heat by cycling on and off, not by reducing a constant wattage. So if you set it for five minutes at 50% power, it will cycle on at full power for however long the cycles last, then off, then on again, etc., until it's has been on for 2 1/2 minutes and off for 2 1/2 minutes.
1st make sure nothing else is using power.
Try to use microwave if it trips see below:
2nd set microwave to 80% power or something less than 100% power. If that works then each time change the power setting and that is the best you can do.
Nope doesn't work. Tried it at 40% with the same results.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
