Gerald55's avatar
Gerald55
Mounting inverter in close proximity to AGM batteries
I'm mounting a 2000W Xantrex inverter in my Pleasureway Excel. By far the most practical place to put it is next to my 4 AGM batteries. That's where the transfer switch is and all the other wiring.
The inverter manual has several warnings against mounting the inverter in the same compartment as the batteries. I assume this is to avoid ignition of battery gasses.
In my case, there is no compartment - the batteries are in the living area, under the bed, and the area around the battery is open on the top. I want to mount my inverter directly next to the batteries. I believe this is safe because my AGM batteries are sealed and hence I don't expect any build-up of gasses, and even in the extreme case that the batteries vented for some reason, it doesn't seem like gas can accumulate much as the space is not enclosed.
Am I out to lunch here?
  • Almot's avatar
    Almot
    Explorer III
    Those manuals were written with wet cells in mind and were not edited after people started using AGM.
    I myself wouldn't like having batteries not separated from living quarters. AGM don't gas under normal conditions, but they do have a purge valve in case if they would. You have to do something really wrong to make them boil and gas.
    Realistically, the only danger of such a placement is the noise of inverter fan in the living area.
  • I have mine within a foot of 6 AGM batteries with no problems. No gassing = corrosion. But I keep an I on it every time I open the compartment. Chino
Having RV issues? Connect with others who have been in your shoes.24,340 PostsLatest Activity: Dec 04, 2025
