pianotuna's avatar
pianotuna
Nomad III
Jun 07, 2013
moving from 225R75/16 to 235R85/16 PROBLEMS
Hi,
More problems have reared their heads.
The E-450 has a different rear axle, than the F-450. The F-450 will allow up to a 245 width with no change of rim size for the rear duals.
The E-450 won't allow anything wider than the 225 size.
Possible solutions:
#1 Get seven Chev rims and have them machined out to fit the Ford axle. However, they MAY not fit around the brake. It would be pretty expensive to find out.
#2 use a 1/4 inch spacer this would still leave the existing rim contact on the hub. Load the water tanks (black grey and fresh) and the gas tank to the brim. Check to see if there is sufficient clearance.
#3 give up and use the OEM size.
What would you do?
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 12, 2026
