Weldon's avatar
Weldon
My Magnetek converter
My converter is 16 years old, it has 2, 30 amp fuses for 12 volt operation. If you only have 1, 30 amp fuse rather than 2 what is the result?
This occured and was this way for a week. Went out to open the slide and it opened fine- operates off the 12 volt system. As we turned lights on, what would be 12 volt, they became dimmer. After setting overnight the battery would build some power but diminish quickly. Battery showed 10.9 volts. All 120 volt items work well.
Volt meter on 2 large wires in front of converter showed 9.9.
Is battery bad and converter?
  • Weldon wrote:
    Someone tell me again how to check the converter to see if it is working. My old battery did have a dead cell. Thanks
    Turn off the converter. Turn on an incandescent light. Observe the color and intensity. Turn on the converter. If the light gets brighter the converter is producing 12 volt power.
    A better way is:
    1. turn off converter.
    2. measure voltage at the battery bank
    3. turn on converter
    4. measure voltage at the battery bank.
    If the voltage went up, all is well.
    The 7300 should hold voltage about 13.6 without a battery or with a good functioning battery.
    Turn on all the lights and the furnace and should still hold close to 13.6 volts.
  • A little follow up, replaced both 30 amp fuses as they were bad. Replaced battery it had a dead cell. Converter / Battery was maintaining 13.75.....thanks for the advice guys.
  • 13.75 is a bit high to float a battery in the TX heat. 13.75 is slow charging if you are trying to minimize generator run time.
    Depending on use, a multistage converter will give better service.
    Glad to hear the issues have been sorted out.
