BruceMc
Oct 05, 2014Explorer III
westend wrote:
BruceMc,
What type of fitting do you have for the roof entry?
Similar to this type: (updated - link to pic of metal fitting was broken)
I mounted it in the hollow aluminum frame rail by drilling into it from the roof, then enlarging the hole with a file. Once large enough, I threaded the fitting into the hole, then removed & added sealant & re-installed it. The result:
I added additional sealant on the grommet where the wires passed through.
By having the connector under the panel, it is out of the sun and rain.
Having RV issues? Connect with others who have been in your shoes.24,200 PostsLatest Activity: Feb 19, 2025
