Passin_Thru's avatar
Passin_Thru
Need engineers thoughts on wheel offset
Travel trailer wheels have either a centered or outside offset. My question is this. I have outside offset wheels and have sheared off wheel bolts on 2 different wheels I have weighed everything and I am 500 Lb/axle below MGWR on each axle. If I move to a centered offset, how will it change the torque and shear on the bolts. I believe that it is being caused by too high a torque load when cornering to the outside at higher road speeds on I 81 in Pa and NY. Will this drop the torque on the bolts and tire? Thanks I am an A&P Mechanic but havent worked much with shear forces.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
