Blacklane
Apr 23, 2022Explorer
Screw-type terminals where you wrap a wire around a screw are not appropriate for a vibration environment, such as in an RV. You need to use clamp style, spring style (also called back-stab), or the original punch-down style used in self-contained devices.
Also, installing self-contained devices is much easier with a special tool for the job. For a single outlet, it will probably be cheaper to just have a professional do it.
Many will claim that household devices are superior to self-contained devices, but that's not really verifiable. Both are usually certified by UL and CCA (check for that) and both are allowed by the US National Electric Code.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
