maillemaker's avatar
maillemaker
Need help replacing charging circuit solenoid.
Last weekend I was driving down the road and my voltage started dropping off while driving. I assumed I had a bad alternator, so I stopped and bought a new one and replaced it, and it did not help.
I pushed my in-cab momentary rocker switch to gang the house batteries to the engine battery and was puzzled that I did not see an increase in system voltage.
So I took my wrench out and whacked the solenoid, and lo and behold the system started charging again.
This is my solenoid:
Hi-res photo of the above is here: https://i.imgur.com/UsT3n2A.jpg
Winnebago will sell me one for about $45, and these guy sell one for $41:
https://www.winnebagoparts.com/3-post-battery-change-over-solenoid/#prettyPhoto
But I believe this is the same, or equivalent, 3-post solenoid, for $17.50:
https://www.amazon.com/May-Continuous-Solenoid-Terminal-71580-75/dp/B0797WZBD9
The above amazon solenoid is rated as "continuous duty", and "200 Amps".
I believe the amazon solenoid will do. What do you all think?
My RV has a 3-way rocker switch. Pushed to the left it will lock, and this will allow the engine to charge the house batteries. Pushed to the right it is momentary (you have to hold it) and it will gang the house batteries to the engine battery for an emergency start. In the middle it is "off" and does nothing.
The Winnebago part number for the solenoid is 008188-01-000
Steve
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
