smkettner wrote:
Go Power has a transfer switch that will isolate the converter.
Might break the bank however.
http://www.boatandrvaccessories.com/gp-power-gp-ts-transfer-switch.html
BTW, where does the utility cord connect?
Most transfer switches can do this. You need to add a fuse to the converter feed and hook them up to the cord side of the transfer switch. In this way when the cord is powered up the converter will be also. Tnen turn off the the timer on the transfer switch. If you are a boondocker then i would suggest you use the relay posts that are normaly closed to the inverter to conserve power.
