grizzzman wrote:
Looks like its 6 guage wire to me.
I You might be right, it's certainly larger than 8ga though.
I ended up ordering the powmax switch, and a samlex 600 watt inverter and remote switch (I trust that brand more, and since I'm using a less powerful inverter I'd rather go with a known good brand).
I haven't done much with 110V electrical in the past. Can I remove the existing converter's breaker and replace it's input wire with a new wire tied to shore power (before or at the junction for the ATS?) Or do I need to buy a new breaker and maybe install it in the ATS box? it would be much harder to access in the box if I ever had to flip it as it will be installed behind the cabinet panel.
