Lightning55's avatar
Lightning55
Need help with dimmer switch
I've got a Jayco Eagle HT 30.5MBOK 5th wheel that has about 7-8 ceiling lights. They are way too bright so I want to install a dimmer switch. The new dimmer switch looks very similar except it has a slide dimmer next to the ON-Off rocker switch. When I pulled out the original switch I determined that the red wire with white stripe is hot. It is looped with a connector that is spliced into the wire that plugs into the back of the switch (see pics). It's 12v hot all the time. The black wire goes to the lights and is powered when the rocker switch is turned on. The new switch has 3 wires and the instructions to hook this up is not at all what they describe the wiring in the instructions that came with the new switch. I'm stumped....It seems that the light circuit is powered up and the rocker switch completes and interrupts the circuit but the dimmer is set up for a different wiring system. Any 12V gurus out there that can give me some help?
Having RV issues? Connect with others who have been in your shoes.24,339 PostsLatest Activity: Nov 28, 2025
