maillemaker's avatar
maillemaker
Need to replace my water pump
My water pump has started leaking. It was made in 08/1990, so it's probably time.
The original pump was a Shurflow 2088-403-144. This is a 3-chamber pump that shuts off at 45 PSI and does 2.8 GPM and draws 4.6 amps max.
http://www.fourwh.com/2088-403-144.pdf
I emailed Shurflow and they recommended:
4008-101-E65
http://www.campingworld.com/shopping/item/shurflo-revolution-water-pump/49007
This is a 4-chamber pump that shuts off at 55 PSI and does 3 GPM and draws 7 amps max.
This is an old RV and I don't want to stress the plumbing system by increasing the PSI, nor do I need increased power draw.
I've emailed Shurflow back to confirm their recommendation.
What do you all think?
This looks like a better match to me?
https://www.freshwatersystems.com/specifications/2088-554-144.pdf
Steve
  • You can put in whatever works. I'm not sure why you're concerned about such a small power draw.
    Mostly I'm concerned about increased pressure in the plumbing.
    My drain valves already leak, and are not accessible to replace. At least the two under the bathroom sink are not.
    They mostly leak when if they are stuck in between fully open and fully closed, but weep even when closed.
    But I'm mostly curious why they would spec out a pump with different operating parameters from the original when it seems like there is a pump out there that matches the original specifications almost exactly.
    Original pump:
    2088-403-144
    Factory Shutoff: 45 PSI
    Max Flow: 2.8 GPM
    Max Current: 4.6 amps
    Supposed replacement:
    4008-101-E65
    Factory Shutoff: 55 PSI
    Max Flow: 3.0 GPM
    Max Current: 7.5 amps
    Best match I found:
    Max Flow: 3.5 GPM
    Max Current: 5.2 amps
    Also the physical form factor of the best match I found matches the form factor of the original more closely.
  • j-d's avatar
    j-d
    Explorer II
    There are diaphragm kits for these. Or did they drop it with the pump?
  • DrewE's avatar
    DrewE
    Explorer III
    The difference in pressure is very unlikely to cause any problems. You can easily get higher pressures if you connect to city water (especially without a regulator), if you fire up the water heater from a cold start with all the taps firmly shut, or even due to the momentum of the flowing water when you turn it off quickly.
    The only reason I can see the power draw being a problem is if the branch circuit is underspecified and has a 5 amp fuse. If that's the case, upgrading it is not a bad idea regardless.
    I would go with the newer model myself in your situation. The shutoff pressure is apparently adjustable, by the way. Setting it to a lower pressure and perhaps installing an accumulator tank (if you don't have one) so it doesn't cycle too much would be reasonable if you wished to do that.
  • SoundGuy wrote:
    The Shurflo Classic i.e. -144 model - has been discontinued. The Revolution is a perfect but much better performing replacement ... own one myself. :)
    Same here. Our old pump was a 1990 version also. Replaced a couple of years ago with the 4008 (Revolution). Has worked very well.
  • The Shurflo Classic i.e. -144 model - has been discontinued. The Revolution is a perfect but much better performing replacement ... own one myself. :)
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
