Munk888's avatar
Munk888
New House Batteries, Converter Beeping?
Hi. Lot's of learning going on! We have a 2003 Fleetwood Tioga and we killed the batteries during storage. Didn't disconnect them and that damned LP detector wiped the batteries out: chassis and house, so we think... So we got a new chassis battery first. Replaced that ez pz. Went to replace the house batteries and that is when the proverbial poo hit the fan. We had 2 Napa deep cycle batteries at 75amps each. I hit autozone and got 2 Duralast 65amps batteries. Swapped em out. So far so good. Kept the wiring the same. Now, when we turn the rig on, there is a shril continuous tone coming from the converter (the plug with all the wires and fuses?) area of the battery compartment. Lights don't turn on. Generator won't kick up. Are converters amp specific? IE, should I swap out the 65amp batteries with 75amp batteries and keep all the things like for like? Any helps appreciated!
imgur pictures
  • Disconnected! Thank you very much! Waiting for picture :) Hopefully I didn't cook something...
  • STOP, you are wired incorrectly disconnect all the negative wires now. You have the 12 volt batteries wired in series making 24 volts.
    Per your pictures you removed two 6 volt batteries correctly wired in series and replaced with two 12 volt batteries. The 12 volt batteries need to be wired in parallel. let me find a picture.
    Here, you need to be wired like the batteries in the LEFT picture. Your old wiring is in the right picture.
    Hopefully you did not blow any fuses. But you'll find out after you correct the battery wiring.
  • Thank you very much for your reply! Good to know that the slightly less amperage set of batteries is not a culprit. Wiring. I duplicated the original exactly to the original as far as I can tell. In the pictures I shared there on Imgur, on the right battery, the negative terminal has a small white and small black wire co-mingling with the big power cable. Do those need to stack in a specific way? I'm also fairly certain that at no time I did a neg/pos tap tap. But, who knows? Maybe I did booger something up unknowingly...thanks again!
  • DrewE's avatar
    DrewE
    Explorer III
    The converters are not battery size specific, at least not in terms of everything working or not working. (If you were to change to a much larger battery bank, a larger converter would be sensible so it doesn't take forever to recharge.) Most likely something is not wired correctly, or a connection isn't sound, or possibly the battery disconnect switch is set to storage mode, or something of that ilk. If things were connected improperly, there is the chance that you may have damaged something in so doing.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
