learningsolar's avatar
Apr 14, 2014
newbie trying to build solar system on a budget
hello everyone.....I was pointed here from popupportal as I am trying to create a decent pv system.....I used to work at a manufacturing plant and so I have 72 cell 240 ish watt panel i am trying to use... voc today in terrible conditions was 45.2 volts with 2.3 amps....but have found controllers to do this job are very expensive....I have removed junction box cover and was able to get 3 circuits at 15 volts which would allow me to use a cheaper controller as I would assume even in the best of conditions I would be under 20 volts amps I would assume would be under 20 and allow me to purchase a cheaper controller....I have a 1500 watt inverter and am going to be using either 2 12 grp 29dc battieries from wallmart or maybe 3 if needed but doubt it... I am on a budget and so trying to do this as cheap as possible while having a good system.....here are some pics of components I am using....also a drawing of how cells are wired within panel....any help would be appreciated...oh ya and this is for my newly purchased coleman Utah tent trailer.....allot of power for a tent trailer but might also be temp camp on lot until built so I wanna make it good....
thanks
mix and match panel with mono and poly cells in it
opened j box with 4 leads and diodes to isolate circuits so if one cell gets damaged whole circuit isn't compromised....I am not worried about that though
and this is how ever circuit is wired.... each string of cells is 12 cells long in series on 72 cell and 10 on 60 cell panels
am I on the right path?? these panels can be purchased very cheap from the manufacturer because of defects but still produce good power and can be used off the grid, everyone avoids this thought because mppt controllers are so expensive to reduce voltage they would rather buy ct solar kit @ 30 watts cuz its plug and play
what are the pros and cons to re-wiring down to 12-20 volts instead of higher voltage???
thanks
  • wow quick reply...still working on pics....todays test condition are terrible...no sun visible and snowing...what should I be looking for for voc? for 12 system, I also have a 60 cell here that gives different numbers too, I could use either
    http://i1144.photobucket.com/albums/o482/goodtimes1210/DSC_0025_zps3628f4ec.jpg
    panel
    j box open
    http://i1144.photobucket.com/albums/o482/goodtimes1210/DSC_0022_zps424d9f04.jpg
    and internal wiring of panel
    same panel split into 2 circuit was 28 volts each but each circuit contains 4 strings which overlap each other, so not too sure what that would show while wired up I would assume they would share voltage and balance out, don't know if I could even do that
  • Hi,
    Welcome to the forums.
    15 volts is a bit too low. By the time the panel heats up in the summer it may not be practical.
    BFL13 has tried a cheap MPPT controller from Ebay.
    Seeing as the panel price is extremely low, I'd "go" for a controller that cost a bit more. Temperature compensation is a "must do" imho.
  • [img][/img]
    circuit of panel
    [img][/img]
    jbox opened with 4 leads showing and diodes used to isolate circuits
    [img][/img]
    panel being used
    I hope this time pics work
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
