beaubeau's avatar
beaubeau
No 110 at outlets
Hi!
New problem here, thanks in advance for any thoughts...
We have shore power -- the A/C, the microwave, and A/C mode for the fridge all work.
But all our 110 outlets (3 inside and 1 outside) are dead.
I've checked all the breakers and they are fine, as are all the 12V fuses.
Everything was fine when we left the camper around 5 hours ago but was like this when we returned. There has been some rain, but no storm.
Any thoughts where I could start troubleshooting this?
Thanks!
(2013 Keystone Passport TT)
  • RoyB's avatar
    RoyB
    Explorer II
    It sure sounds like a tripped GFCI receptacle. You should have one of these installed where you may come in contact with water like the kitchen area, bathroom area, or wash up sink near the bedroom etc.. Those are the three areas in my trailer.
    the GFCI Receptacle will look similar to this google photo... One GFCI receptacle will control several additional regular receptacles downstream from its wiring...
    My outside receptacle on the side of the trailer is controlled by the GFCI Receptacle in the kitchen area. Since you have had alot of rain this outside receptacle would be very suspect to me of possible getting some moisture perhaps...
    Roy Ken
  • Sure sounds like a GFI has been tripped. Check your outside outlet for a GFI. They are not usually put there but they are sensitive to moisture. If the GFI is not outside but won't stay on after resetting it, check the outdoor outlet for moisture.
  • I agree, check the GFI and see if it has tripped. The GFI is usually in the bathroom and will be just like a 110 outlet but will have a couple of buttons in the middle. If one button is OUT, reset it and then check if the power has been restored.
    GFI
  • BTPO1 wrote:
    Check all of your GFCI's and reset the one that is tripped. JMO
    Yep! ^^^^
    usually it's the one in the bathroom.
  • Check all of your GFCI's and reset the one that is tripped. JMO
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
