westend
Nov 12, 2016Explorer
First, check that power is present beyond that fuse in the black cable to your battery when properly connected. There may also be a hidden circuit breaker close to the battery. Look for a small can that houses the breaker. It may need resetting.
As OB states, if you connected 12V backwards, you may have blown the reverse connected protection fuses on the converter.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
