linnemj's avatar
linnemj
No DC power to trailer, batteries good
Our trailer has power when plugged into AC but no power with the batteries. Batteries are almost new and ready 12.7 - fully charged when checked with a meter. I made sure the battery cut off switch is on ( turned on and off several times) and all the fuses in the inverter look good.
What am I missing? I looked for a in-line fuse between the batteries and inverter with no luck. Your help is appreciated!
  • Wanted to post the resolution of the issue. I hired a RV tech and he found the breaker was inside the V nose of our trailer where the battery cable runs from the battery box. It was a 30 amp breaker. He replaced is with a self resetting breaker.
    Thanks to all for your suggestions. I got a lesson from this experience.
  • X2 on the breaker Mex pictured and advised to use.
    That is a Cooper-Bussmann product. Lower current models are available.
  • Use the garbage breakers on circuits you can live without until you do a hot swap
    This is the breaker you want to use on the really important stuff. They are around 900 times "tougher" than a garbage breaker
  • linnemj wrote:
    Our problem with the DC happened after returning from a 8 week trip. Batteries worked fine for 4 weeks and they test well.
    I have been unable to find an inline fuse or breaker to date.
    Thanks to all for your help! When it quits raining here, I can continue the search for the issue.
    OK then 'reverse polarity' fuses on converter are OK
    With a voltmeter check voltage on battery side and on trailer side of 'disconnect switch'....is it really working when you turn it ON?
    And follow positive cable from battery to where it goes into trailer.....the in-line fuse (or Circuit breaker) are typically under tongue of trailer (It's like a scavenger hunt)
  • Our problem with the DC happened after returning from a 8 week trip. Batteries worked fine for 4 weeks and they test well.
  • I buy 'em by the bag full for $1.48 but for important work they are worth even less. A surface mount genuine breaker available at genuinedealz, allbatterysales, or delcity.net cost about 20 dollars and may save you the cost of a hair transplant. Little breakers seem to do fine in the 15-amp range. 30-amps and above they don't seem to live a reliable lifespan.
  • Battery almost new...........
    Have you had this 'no DC from battery' issue since new battery was installed OR something that has just happened?
    Since new battery install.......Check on converter for large amp fuse(s) (30A or larger). Could be on front or backside of converter. They are 'Reverse Polarity' fuses. IF battery got hooked up backwards...they blow. No DC from battery but DC from converter works. No charging of battery by converter either.
    Bad disconnect switch
    Bad in-line fuse/DC circuit breaker under tongue
    Blown Reverse Polarity fuses
  • I had the same problem awhile back. It turned out to be a circuit breaker.Looks something like this
  • Get out your multimeter. Check that you have power on both sides of the battery fuse, then check both sides of the cut-off switch, finally check power as it comes into the 12v distribution panel.
    At some point you will find 12v on one side of something and zero on the other. Clean, tighten, or replace that item.
    And yes there are sometimes a breaker that is well hidden with poor access.
  • We had a circuit breaker installed under the rig near the front. I never knew it was there until our DC died at the dealers. It was the kind that had to be manually reset! The dealer changed it to an automatic reset model.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
