bpounds wrote:
Main problem is OR. Can't pump your own.
That applies to gasoline only. You can pump your own diesel in OR. In fact, one place I was in last week posted a sign that if you wanted diesel then you had to pump it, they would not. Which was fine with me as I am used to pumping my own fuel. The hitch in the giddy up was only the attendant could operate the pump control system (i.e. run credit card, etc). Getting him to come over and do his portion took forever. My role was limited to squeezing the handle on the dispenser.
