Hughesii's avatar
Hughesii
No power to the front of a 2003 newmar dutch star.
Hopefully I'm posting this in the right place.
Went to start my motorhome last friday for us to go away for a few days and when I turn the key on nothing lights up on the dash, the leveling panel also doesn't come on and the generator doesn't start from the panel inside or at the generator. Everything was working on saturday when I started it and moved it, I did disconnect the batteries and cleaned the cables but I've doubled and tripled checked that everything is hooked back up and hooked up correctly.
I don't even see any power coming to the dis-connect switch, both batteries are showing 12v, I don't know where to check next.
  • Hi, I just had basically the same problem. I tested everything one of the last was the chassis-disconnect switch, disconnected it and clamped the wires together, to test and everything worked. It would help to know your chassis and motor.  Info makes the world go around.
    • way2roll's avatar
      way2roll
      Navigator III
      Your response is a little snarky. Given that you are new here you may want to familiarize yourself with the forum and attention to topic dates. The OP posted this about 7 months ago and hasn't returned. You can see the last activity of a user by clicking on their user name.
  • Duplicate post. the mods have already moved your post to the appropriate section, and it looks like you are getting responses/responding.
