- Rickkessler54Explorerwe had the same problem with our camper the very first time out, ever. we thought we were doing something wrong so we took it back to the dealer to check it out. Turned out that when we filled the fresh water tank there was sand in the water. The dealer ended up putting a new filter in and solved the problem.
- HelimechExplorer
Helimech wrote:
Bad pump, Check Valve, Winterizing valve closed, Plugged water line?
Is it busy filling up the WH?
Wow, I didn't think of that one. - Old-BiscuitExplorer IIIFilling up WH is one of the things.
Check pump inlet side for any air leaks
Open the closest faucet and expel the air in lines - ScottGNomadIs it busy filling up the WH?
- Alfred622Explorer1) do you have a low point drain just after the pump? If so open it and turn pump on - that will tell you if pump is pumping. If not, then it could be a problem with the pump or prime.
2) Can you run city water under pressure into your TC? That will tell you if the plumbing to your faucets is good. - HelimechExplorerBad pump, Check Valve, Winterizing valve closed, Plugged water line?
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
