az99
Jan 15, 2014Explorer
Norcold 10cu. ft. Residential Replacement
I would like to replace my Norcold N109X frig with a residential frig. Most of the posts I can find are replacing larger units with the Samsung 197 which is far too large for mine.
The Norcold is 23-1/2"W x 60"H x 24"D.
Has anyone replaced this frig and what did you use as a residential replacement.
I have an 1800 PSW inverter and 4 batteries so I should be OK to run it.
Thanx
Thanx
