YC_1
Apr 04, 2018Nomad
joebedford wrote:
I haven't seen any residue in the compartment behind the fridge or inside for that matter.
There are fans and they come on. The fridge is in a slide. I pulled the exterior covers off and can see no obstructions. There is heat coming out the top vent.
Not sure what drain hoses you mean YC 1. There is a condensate drain hose that goes into a little metal cup thingy - but only one. It looks fine.
No gurgling when it's running.
How hot should the leveling chamber be? It's warm but not too hot to touch. I guess it's the least warm part of the system right before the burner.
There may be a tee in the drain lines. It is possible they are cracked. Does the hose feel brittle?
Since you saw the fans coming on that should not be an issue.
Something has changed.
If you are running on propane the chimney might be plugged and may need a cleaning.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
