Alpinexplorer's avatar
Jul 06, 2016
Norcold 1200 Boiler Temperature Sensor
I just had my first experience with my refrigerator shutting down and the dreaded red light coming on for the overheat sensor. I had been boondocking for several weeks running on propane and had just connected to electric when the problem occurred. The red light came on about four hours after connecting to electric.
About 12 hours later I successfully reset the sensor with a magnet and the refrigerator started up again. It's been running on propane without problem for about a month now. I have not switch back to electric out of concern that my problem could be connected on electricity. I'm writing to see if anyone with technical expertise knows if the temperature sensor trips differently for propane vs electric. For example, I assume when running on electric there's a thermostat that controls when the electric heating element turns off. Is this thermostat different than the one that monitors temperature when running on propane. I'm basically trying to decided if I need to get the unit checked out by a technician. I realize I can just try running it on electric again and see what happens, but I don't want to overheat the boiler needlessly.
  • Alpinexplorer wrote:
    Hi Doug. Thank you very much for your reply. That was exactly what I was looking for. My recall sensor is a Rev E. From your reply it sounds like I probably have nothing to worry about. I was just assuming that a high flue temp could be caused by a malfunctioning thermostat. Is there anything you recommend doing before I try plugging the AC back in?
    Thanks, ... Christopher
    No, just put it on electric and see what happens. Doug
  • Hi Doug. Thank you very much for your reply. That was exactly what I was looking for. My recall sensor is a Rev E. From your reply it sounds like I probably have nothing to worry about. I was just assuming that a high flue temp could be caused by a malfunctioning thermostat. Is there anything you recommend doing before I try plugging the AC back in?
  • 120 Electric and LP flame has no bearing on the overtemp sensor. All the sensor does is sense the flue temp. The normal temp operation is 350 degrees. The Recall sensor trips at 700 degrees. You need to post what Revision is on the Black recall box. LOW dc voltage cause false trips on the early Recall revisions. Revision E is the newest. The 120 elements(2) can run all the time and never cause overheating if the ventilation is correct and you have no ammonia leaks. The same Thermister regulates the 120 and LP. Doug
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
