dougrainer
May 28, 2018Nomad
Grey Mountain wrote:
My Norcold appears to be belly up. Getting an error code "cooling unit inopertive." Don't know if your problem could be similar. My unit would not work on propane, but would work on shore power. Then, after a couple of days, it would not work on anything and I was getting the above error code. Mine may be an anomaly, and yours could be entirely different, but who knows?
GM
You are NOT getting a code --Cooling Unit inoperative. NO SUCH CODE. And I told you on another or your posts, NO RV refer has a cooling unit failure code. You either have NO CO, or Li-OP.
1.NO CO means NO cooling and you have a problem that you failed to fix and the refer controls have locked you out until you do a hard reset and find and fix the problem
2. Li OP is the same as NO CO, just an updated message on newer 1200 control systems.
They both mean finds the failure of why the Refer failed to cool correctly and once that is done you reset the failure code. Doug
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 11, 2026
