hypoxia's avatar
hypoxia
Norcold 1200 Preventative Maintenance
I am installing a cooling unit today in my Norcold 1200. I started wondering if any parts should be replaced while I have access to the back. I plan to add a third fan which will be connected to the solar panel on top of the air conditioner as well as a baffle on the condenser.
  • dougrainer wrote:
    Replace BOTH fans and the fan tstat. From the Fan tstat, run a wire from each side of the tstat down the back to behind the refer to manually test or run the fans when there is a problem. Have your 3rd fan blowing OUT the top on top the refer. Doug
    Somehow I missed your post yesterday. I had seen that advice on a post you did a while back and ran the wiring as suggested. I set up the solar panel fans to run one beside the two factory fans and one on top of the vent. They both blow upwards.
  • pianotuna wrote:
    Hi hypoxia,I am not talking about fire protection. I'm talking about "out of level" operation protection.
    That may be a good thing to have, I haven't given it any consideration yet.
    One thing I did per Doug Rainer's advice is run a wire to enable testing the fan thermostatic switch easily. It also provides the ability to bypass the switch and power the fans independently.
  • Hi hypoxia,
  • Thanks, I cleaned the drain tube which was full of debris. Everything I read claims the fire protection is not needed with the Amish Unit.
  • I would replace the drain tube. Be sure to replace any components that might be in the end of the tube as well. There may be a device to hold back some water to keep warm air out of the refer.
    Loosten any ground wires that are held down and clean and retighten.
  • Replace BOTH fans and the fan tstat. From the Fan tstat, run a wire from each side of the tstat down the back to behind the refer to manually test or run the fans when there is a problem. Have your 3rd fan blowing OUT the top on top the refer. Doug
