dougrainer
Aug 01, 2022Nomad
The 12 volt section of your 3 way is a MAINTAINER of existing interior temps. It is NOT designed to cool the refer DOWN to operating temps. So, if you have the refer at operating temp, then you MUST have the engine running to run the 12 volt heat element to MAINTAIN the existing temp in the refer. 12 volt 3 way refers must have the engine running to function on 12 volts. You must use 120 or LP to get the refer to operating temps. Doug
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 10, 2026
