dougrainer
Oct 12, 2013Nomad
1. Your refer is NOT original OEM. Your Cooling unit has been replaced with an aftermarket
2. The areas you show are the 120 and 12 volt wiring
3. HAS the recall been done. If NOT, WHY would you continue to operate the refer AFTER your first Fire/Smoke incident?????????
4. The recall is NOT for you to do. You must take it to a Norcold Auth Service center for them to evaluate and install the new Gas valve assbly IF, the refer is determined to qualify since the Refer has been modified over the years
5. Norcold will NOT allow YOU to do anything at all. Doug
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
