chuckt56
Aug 25, 2013Explorer
norcold 611n
i'm sure from what i have seen several people have had similar problems so hopefully i can get an answer, i have a norcold n611 that will not cool in ac mode but will in gas as long as the ac cord is unplugged from the trailer or i have no ac going to the trailer, the gas will work until i plug the ac cord in or start the generator then the gas shuts off and it doesn't matter if the switch is in gas or auto it does the same thing and shuts off. the ac heater is good but i bought a new one and replaced it just to make sure and it still did the same thing.i also checked voltage to the power board @ 108 vac that is what it should have according to the manual also the manual says change the power board the power board is also new i have not tried another power board yet but i have reset it numerous times and it seems to repeat the no co code immediately after i return power to the refrige after resetting it i hope i did not get a bad board. has anyone had this problem before?
