- rogerramjet442Explorermy machinist friend is going to go the route of some metal etc, i sure am glad the part about the bottom trim was brought out, was going to pry off to work on it. mine pulled completely out of the foam junk, sure is a p--- poor design and Norcold should have bit the bullet and owned up to it.
- fcooperExplorer II
Fleet Man wrote:
Recommend you get a piece of metal to attach to the bottom of the door under the hinge after you "glue" the broken hinge back together. Drill a hole through the reglued hinge and the metal plate and then reinstall the door. That should be the last time you experience that failure on that door hinge. I have a piece of 1/8" metal attached to the bottom of the door and angled out to the hinge with a hole for the hinge pin.
Assuming that the door is similar construction to the Norcold NB811 I had, do not attempt to pry off the bottom trim strip as it is glued to the interior foam core of the door. I tried to make a metal strip for the bottom of the door, but there was nothing solid inside the door for screws to get a grip into....it's all foam.
I now have a nice Haier 120 volt refrigerator installed that we like.
Fred - Fleet_ManExplorerRecommend you get a piece of metal to attach to the bottom of the door under the hinge after you "glue" the broken hinge back together. Drill a hole through the reglued hinge and the metal plate and then reinstall the door. That should be the last time you experience that failure on that door hinge. I have a piece of 1/8" metal attached to the bottom of the door and angled out to the hinge with a hole for the hinge pin.
- rogerramjet442ExplorerThanks gang ! for all the info, was considering the J B knew some one else must have had the sme or similar problem.
- NHIrishExplorerTry using JB Weld and add the Norcold RV Refrigerator Door Hinge Kit #634166, available at Amazon and elsewhere.
- ljrNomadNorcold has a reenforcing kit to avoid the problem next time.
- peaches_creamExplorer
chiefneon wrote:
Howdy!
We had problems with out Norcold 1200 door hinges breaking. Both times I removed the door and used J B Weld to glue the hinge back to the door. Never had a problem with them after that.
"Happy Trails"
Chiefneon
I know of some airplanes flying around held together by JB Weld. :W - chiefneonExplorerHowdy!
"Happy Trails"
Chiefneon - the_bear_IIExplorerLots of manuals here
http://bryantrv.com/index.html
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
