Wishbone51's avatar
Wishbone51
Norcold Fridge - Ice on Fins
I have an older Norcold 1200-series unit with the cooling unit recently replaced. Always keep it level. I recently installed one of those wireless temp read-outs with remote sensors that go in the freezer and fridge. It seems to be a device whose main purpose is to give me something new to worry about. :)
My fridge normally gets to -3F in the freezer and 31F in the fridge on the highest setting. I had an issue this past weekend where the fridge wouldn't get any colder than 41F all weekend. Freezer was 24. I was thinking that my cooling unit was going bad.
I did notice that there was ice on the fins inside the fridge. I turned the fridge off and on a couple times to avoid the Norcold 49-hour defrost cycle and the inevitable warming that it causes. My question: Does the ice on the fins somehow insulate it and prevent it from cooling down?
When I got home, I let it defrost and when all moisture was gone from the fins, I started it back up again, and it was cooling as it normally did.
Any idea what is causing the warmer temperatures when in use? I know that opening the fridge does cause significant warming, but I expected it to cool back down overnight, which didn't happen.
Any good way to prevent moisture on the fins? I heard that installing fans might help with this.
Thanks for listening :)
Wayne
Having RV issues? Connect with others who have been in your shoes.24,353 PostsLatest Activity: Jan 23, 2026
