dougrainer
Jul 31, 2013Nomad
Theo w wrote:
Well folks I put a new spark/sensor and still no go. Symptoms are still the same. Will try and call Norcold and see if they will help and if you have any more suggestions I will sure give them a try.
Thanks again
Theo
ONLY 2 things to the LP system
1. The spark electrode and wire (you have replaced)
2. The control board is bad---unless you take it loose and check the solder connections on the Piezo tower as I explained above. IF they are loose, you can solder them and make it work without buying a new board
Doug
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
