Old-Biscuit
Jul 03, 2015Explorer III
Ron Nielson wrote:Old-Biscuit wrote:
3 days of running empty and freezer 27*F and food section 50*F-------cooling unit is NOT functioning
I suggest you turn it off for at least 2 days.....let it completely warm up and then unplug electric element from circuit board. Plug it directly into AC power source and run it 24 hrs.....force cool it/bypassing circuit board--thermistor.
IF it doesn't cool down in 24 hrs--bad cooling unit
I was hoping that you wouldn't tell me that, but I was definitely leaning that direction. Will do the test to see what happens.
Does the fact that it operates same on gas vs electricity tell you anything?
YES..cooling unit
One outside possibility...thermistor not being sensed but fridge should have gone into 'backup operation'----kind of a limp mode but instead of cooling based on thermistor........cooling cycle is based directly on temp set point and you have to change it to get cooler/less cooler temps
What day did you mess with thermistor and change temp setting from 5 to 7?
Day 3 day 5?
DO the direct electric element test.
Have you checked the 'diagnostic screens'?
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
