Old-Biscuit
Jul 04, 2015Explorer III
Ron Nielson wrote:Old-Biscuit wrote:Ron Nielson wrote:Old-Biscuit wrote:
What day did you mess with thermistor and change temp setting from 5 to 7?
Day 3 day 5?
DO the direct electric element test.
Have you checked the 'diagnostic screens'?
Believe that was day 3. Not absolutely certain.
Diagnostic Screen Results:
#1 - Diagnostic mode active- Results OK all segments lit
#2 - Led Segments Reliability Check - OK
#3 - Thermistor Fin Temperature - OK - 62*
#4 - Stored Faults - OK received Door Ajar and Ignition Fault
#5 - Stored Fault History - Thermistor Failure (possibly because I removed thermistor from fins?)
#6 - Erase Fault History - done
#7 - Power Board Inputs - thermistor sensing fin temperature
#8 - Power board outputs - AC power to AC heater and DC power to divider heater
#9 - Power Board DC Voltage Status - DC voltage normal
#10 Power Board AC Voltage Status - AC voltage normal
Will do the AC direct power tomorrow.
#3..thermistor fin temp---62* :H
Is fridge OFF?
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
