Skid_Row_Joe
Jul 04, 2015Explorer
BFL13 wrote:Correct. Bang on the chimney once a year and vacuum up the residue that falls to the base of the flue. The burner will need to be wire brushed every so often too. Good input!
Long shot, but a 2008 would have time by now to get some crud on the burner slots, reducing the flame.
There is a procedure for cleaning that and clear the slots. At some point, the chimney above the slots gets big flakes of soot that keep dropping down across the slots and you get an "F" on the dial. Then you have to go in there and clear the big flakes out of the way and bang on the chimney to get any loose ones down before you put it all back together.
You might be at the point where the slots are getting plogged up, but not so badly yet that you get the dreaded "F"
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
