Ron_Nielson
Jul 05, 2015Explorer
Old Biscuit
I will do the direct AC connection for the heater today. I'm assuming that the purpose of this is to 1) bypass any function of the board 2) to see if the heater produces sufficient heat. When I do the test, do you want the board attached to 12V power? to 110V power? My thought is that neither 12V nor 110V is necessary - that the heating of the cooling unit with the 110V heater alone will operate the unit without control. And for how long? 24 hours? 48 hours?
This is from the Norcold manual and comes from the troubleshooting chart:
Temperatures given below are based on 90 °F ambient
temperature, correct ventilation, and operation at coldest
setting for a period of 8-12 hours.
? Freezer -5 °F to -10 °F.
? Fin temperature 18 °F to 25 °F.
So it appears that the refer should get to temperature much more quickly than many of them do.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
