Ron_Nielson
Jul 26, 2015Explorer
Gene&Ginny wrote:Ron Nielson wrote:What is the voltage to the heater leads when it IS being regulated by the control board?
... Only thing different is that the leads for the heater were supplied 120V separately and without being regulated by the control board. ...
Could there be a bad connection in the 120 volt wiring causing low voltage and poor element heating?
Great question and I don't (exactly) know the answer. However, the voltage to the interior circuits of the trailer was 114-116 while I was doing my testing. I didn't test the receptacle for the fridge to see voltage there. I didn't test at the board connection to the heater either. My GUESS is that the heater itself was seeing something less than 114-116, based on the comparative results of direct feed of the 120V circuit to the heater, and my GUESS is that the board needs to be replaced.
Don't you hate it when there is so much GUESSING? Before I purchase a new control board, I will be sure to measure the voltage at several points to see if the problem is elsewhere in the circuitry, not in the board as is my GUESS.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
