wnjj
Jul 27, 2015Explorer II
Ron Nielson wrote:
Yes, the picture is the exact number of the board in my trailer. I got the number from the board, went to Amazon, selected the board and put in in the cart, then marked it 'save for later'. I did not check to see the labeling of the relay, k1 k2 etc to compare to the picture or a wiring schematic. The trailer is a 2009 model but was built in 2008, August, IIRC.
Do you want me to remove the board cover so that I can visually see the board? Maybe I'm looking at the wrong relay?
Here's an Omron replacement available (but backordered a little) on digikey. It has the same footprint, 5VDC coil voltage and current as the Goodsky one. The only difference is a 16A AC contact rating instead of 15A (more is better but the contact need only support a couple amps for the heater anyway.
http://www.digikey.com/product-detail/en/G5LE-1A-E-36%20DC5/Z5217-ND/1815659
Here are the two datasheets for reference:
Omron datasheet
Goodsky datasheet
Apparently Norcold did change the board design some so the schematics I linked may be off a little. The manual I found has a 16-pin connector which apparently they changed to separate 10-pin and 6-pin ones in recent designs. If your board matches the Amazon one, the Omron relay will work.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Aug 06, 2017
