jcpainter
Aug 30, 2015Explorer
Ron Nielson wrote:Old-Biscuit wrote:Ron Nielson wrote:Old-Biscuit wrote:
What day did you mess with thermistor and change temp setting from 5 to 7?
Day 3 day 5?
DO the direct electric element test.
Have you checked the 'diagnostic screens'?
Believe that was day 3. Not absolutely certain.
Diagnostic Screen Results:
#1 - Diagnostic mode active- Results OK all segments lit
#2 - Led Segments Reliability Check - OK
#3 - Thermistor Fin Temperature - OK - 62*
#4 - Stored Faults - OK received Door Ajar and Ignition Fault
#5 - Stored Fault History - Thermistor Failure (possibly because I removed thermistor from fins?)
#6 - Erase Fault History - done
#7 - Power Board Inputs - thermistor sensing fin temperature
#8 - Power board outputs - AC power to AC heater and DC power to divider heater
#9 - Power Board DC Voltage Status - DC voltage normal
#10 Power Board AC Voltage Status - AC voltage normal
Will do the AC direct power tomorrow.
Ron, how do you get get these diagnostic results on the N82? We have the same model and are having similar problems.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Aug 06, 2017
