Old-Biscuit
Dec 09, 2014Explorer III
chucknmare wrote:
Bummer took ohm reading on heater coil and it says it is close to what it is supposed to be. Should be 40.3 ohms and reads 39.8 ohms. Not sure if it makes a difference if it is hot or cold. Running on gas so the tube is hot. Might go to take a reading on new one prior to buying.
To get correct resistance reading on heater element is should be at ambient temp......so fridge needs to be off and stack cold or pull heater out of tube and let it cool down before testing.
